Hello,
I have a problem. After I logged in today, my pins are saved, but the map did not load. I can only see white page intead of map, also the list of the pins did not appear. They are all saved, I can see them in settings, but not on the list.
I use Google Chrome. The map loads properly on my iPad, also when I use IE7, but it is very slow.
Thanks for Your care.
No map
- 619 Views
- Last Post 18 November 2015
Vitek
posted this
18 November 2015
Admin
posted this
18 November 2015
Yesterday I made a change in the script file; please clear your browser cache file logout of the system and login again. That should take care of the problem. You can also try to refresh the page. Thanks
