Bulk Pin Add from Another PinMaps Map
  • 2.8K Views
  • Last Post 09 August 2018
SCGL posted this 02 August 2018
I want to copy all of the pins from one map and add them to another map. Is there an easier way to do this other than importing the data for the pins via an Excel spreadsheet?
Order By: Standard | Newest | Votes
Admin posted this 03 August 2018
Yes, you can copy / move pins from one map to another one within the same PinMaps account.
On you maps page, click the "My Account" tab located on the right hand side of your map,
From there, click the "Move Map Points" or the "Copy Map Points" link and follow the instructions.
SCGL posted this 09 August 2018
It worked! Thank you very much!
Close
