How do I delete a location and Pin that I no longer need? thanks
How do it delete a pin
- 1.2K Views
- Last Post 20 November 2015
Roxanna
posted this
20 November 2015
Admin
posted this
20 November 2015
Select a map point from the list located at the right hand of the map, then click the "Delete Map Point" button on the toolbar that is located right above the map.
When you select a map point from the list several links will be displayed on the tool bar. The toolbar has the links or buttons needed to add, delete or edit maps and map points.
