Error when using API
  • 1.2K Views
  • Last Post 05 January 2016
Joel Collins posted this 31 December 2015
I'm getting the following error when trying to use the /v1/pins api
<Error>
<Message>Something went really bad. LinkToVirtualEarth</Message>
</Error>
All other query APIs that I checked seem to work.
Order By: Standard | Newest | Votes
Joel Collins posted this 05 January 2016
Indeed its working now.  Thanks for the quick response.
Admin posted this 04 January 2016
The API issue has been fixed and should be working correctly now.
Thanks
We found the problem and we'll have the fix ready by the end of this week.
Thank you for reporting this isse.
Admin posted this 01 January 2016
Thank you for letting us know. We'll investigate the issue and will let you know as soon as it is fixed.
Close
